Saltar al contenido principal
Sony Cyber-Shot DSC-H1 Lens Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: paso 1, imagen 1 de 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 2, imagen 1 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 2, imagen 2 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 3, imagen 1 de 2 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 3, imagen 2 de 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 5, imagen 1 de 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: paso 6, imagen 1 de 2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: paso 6, imagen 2 de 2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 7, imagen 1 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 7, imagen 2 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 7, imagen 3 de 3
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 8, imagen 1 de 2 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 8, imagen 2 de 2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 9, imagen 1 de 1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 11, imagen 1 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 11, imagen 2 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 11, imagen 3 de 3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: paso 12, imagen 1 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 12, imagen 2 de 3 Sony Cyber-Shot DSC-H1 Lens Replacement: paso 12, imagen 3 de 3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Conclusión
3 personas más completaron esta guía.
Charlie Pugeda
Miembro Desde 03/19/18
505 Reputación
3 Guías creadas
Equipo
Baylor, Team S5-G4, Williams Spring 2018 Miembro de Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 18
Todo El Tiempo: 1,575
