Introducción
This guide shows the user how to remove the Sony Clie’s rear cover case, which exposes the inside of the device to replace its internal components.
Qué necesitas
Use the Phillips #1 screwdriver to remove the four screws from the back of the rear cover.
Use the Phillips #1 screwdriver to remove the screw on the right side of the rear cover.
Use the Phillips #1 screwdriver to remove the screw on the top of the rear cover.
2 personas más completaron esta guía.
