Saltar al contenido principal
Sony Clie PEG-UX50 Rear Case Replacement
Qué necesitas
  1. Sony Clie PEG-UX50 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Tools Needed
    • Phillips Screwdriver
    • Tweezers
  2. Sony Clie PEG-UX50 Rear Case Replacement: paso 2, imagen 1 de 3 Sony Clie PEG-UX50 Rear Case Replacement: paso 2, imagen 2 de 3 Sony Clie PEG-UX50 Rear Case Replacement: paso 2, imagen 3 de 3
    • Using Phillips screwdriver, remove 4 screws from the rear cover.
    • Remove 1 screw from the right side.
    • Remove 1 screw from the top.
  3. Sony Clie PEG-UX50 Rear Case Replacement: paso 3, imagen 1 de 2 Sony Clie PEG-UX50 Rear Case Replacement: paso 3, imagen 2 de 2
    • Gently pry rear cover to remove USB port cover and Hold Switch.
  4. Sony Clie PEG-UX50 Rear Case Replacement: paso 4, imagen 1 de 2 Sony Clie PEG-UX50 Rear Case Replacement: paso 4, imagen 2 de 2
    • Remove side cover.
    • Gently pull the rear cover to separate from device.
  5. Sony Clie PEG-UX50 Rear Case Replacement: paso 5, imagen 1 de 1
    • Slowly pull rear cover from device being careful not to pull the speaker connection wire.
    • Remove speaker wire from device.
    • The rear cover is now separated from the device.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 4,114
