Introducción
Before taking apart your device, make sure that you have the proper tools to do so. We used a small screwdriver to remove the screws because they are so tiny. Also, make sure that you are working in an area that is clean and clear of debris so you can see all the parts of your device as you take it apart.
Qué necesitas
Use a #00 Phillips screwdriver to remove screws on the back plate and the side of the device.
Casi Terminas!
Conclusión
