Saltar al contenido principal
Sony Clie PEG-T615C Thumb Dial Replacement
Qué necesitas
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: paso 1, imagen 1 de 1
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: paso 2, imagen 1 de 1
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: paso 3, imagen 1 de 1
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: paso 4, imagen 1 de 1
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: paso 5, imagen 1 de 1
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: paso 6, imagen 1 de 1
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: paso 7, imagen 1 de 1
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: paso 8, imagen 1 de 1
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: paso 9, imagen 1 de 1
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: paso 10, imagen 1 de 1
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: paso 11, imagen 1 de 1
    • Pull plug straight up to remove from board.
Conclusión
Rob
Miembro Desde 10/04/11
1 Reputación
2 Guías creadas
Equipo
UW Stout, Team 5-6, Zhou Fall 2011 Miembro de UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,076
