Saltar al contenido principal
Sony Clie PEG-T615C Battery Replacement
Qué necesitas
  1. Sony Clie PEG-T615C Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: paso 2, imagen 1 de 1
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: paso 3, imagen 1 de 1
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: paso 4, imagen 1 de 1
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: paso 5, imagen 1 de 1
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: paso 6, imagen 1 de 1
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: paso 7, imagen 1 de 1
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: paso 8, imagen 1 de 1
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: paso 9, imagen 1 de 1
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: paso 10, imagen 1 de 1
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: paso 11, imagen 1 de 1
    • Remove the battery by sliding it out of the side of the device.
Conclusión
Rob
Miembro Desde 10/04/11
1 Reputación
2 Guías creadas
Equipo
UW Stout, Team 5-6, Zhou Fall 2011 Miembro de UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 2,279
