Saltar al contenido principal
Sony Clie PEG-SL10 Motherboard Replacement
Qué necesitas
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: paso 3, imagen 1 de 1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: paso 5, imagen 1 de 1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: paso 6, imagen 1 de 1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: paso 7, imagen 1 de 1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: paso 8, imagen 1 de 1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: paso 9, imagen 1 de 1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: paso 10, imagen 1 de 1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: paso 11, imagen 1 de 1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Conclusión
Emily
Miembro Desde 10/18/11
3 Reputación
3 Guías creadas
Equipo
James Madison, Team 1-4, Allen Fall 2011 Miembro de James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Miembros
4 Guías creadas
Un comentario
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,346
