Saltar al contenido principal
Sony Clie PEG-NR70 Speaker Replacement
Qué necesitas
  1. Sony Clie PEG-NR70 Speaker Replacement, The Case: paso 1, imagen 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Replacement: paso 2, imagen 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Replacement: paso 3, imagen 1 de 2 Sony Clie PEG-NR70 Speaker Replacement: paso 3, imagen 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: paso 4, imagen 1 de 2 Sony Clie PEG-NR70 Speaker Replacement, Speaker Rail: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Replacement: paso 5, imagen 1 de 1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
  6. Sony Clie PEG-NR70 Speaker Replacement, Speaker: paso 6, imagen 1 de 1
    • Hold back the plastic tabs to pop the speaker out of the rail.
Conclusión
Daniel Soski
Miembro Desde 04/18/13
57 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-11, Maness Spring 2013 Miembro de Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 317
