Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Clie PEG-NR70 Memory Module Replacement
Qué necesitas
  1. Sony Clie PEG-NR70 Memory Module Replacement, The Case: paso 1, imagen 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Memory Module Replacement: paso 2, imagen 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Memory Module Replacement: paso 3, imagen 1 de 2 Sony Clie PEG-NR70 Memory Module Replacement: paso 3, imagen 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Memory Module Replacement, Memory Module: paso 4, imagen 1 de 1
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Memory Module Replacement: paso 5, imagen 1 de 1
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
Conclusión
Equipo
Cal Poly, Team 14-11, Maness Spring 2013 Miembro de Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
Miembros de 5
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 59
Todo El Tiempo: 811
