Saltar al contenido principal
Sony Clie PEG-NR70 Battery Pack Replacement
Qué necesitas
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: paso 1, imagen 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: paso 2, imagen 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: paso 3, imagen 1 de 2 Sony Clie PEG-NR70 Battery Pack Replacement: paso 3, imagen 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: paso 4, imagen 1 de 2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: paso 4, imagen 2 de 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: paso 6, imagen 1 de 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
Conclusión
3 personas más completaron esta guía.
Courtney
Miembro Desde 04/19/13
49 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-11, Maness Spring 2013 Miembro de Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Miembros
8 Guías creadas
Un comentario
Hi, this is really helpful, thank you.
Richard Hancock - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 37
Todo El Tiempo: 2,181
