1. Remove screws from down
    • Remove screws from down
    • Remove screws from sides
    • Gently take out the from of deck from metal base.
  2. Remove left side black wire
    • Remove left side black wire
    • Remove white contact strips
    • Remove little screw to change ruble inside deck mechanims
    • Remove power suply grey wires
    • Remove the small screw
    • Then you can see the place of the weel. Chnage the ruble.
    • Replace the big belt.
    • Replace the small (green) belt.
    • Use a little tape to old the belt. When closing remove the tape.
    • Insert little screw and close the deck with new belts.
    • Plug all the wires and strips.
    • Close everything, and your done
    • Hope it help, please leave a comment.
Conclusión
Para remontagem de seu dispositivo, siga estas instruções na ordem inversa.
Cafony
Miembro Desde 17/02/15
275 Reputación
3 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 10
