Saltar al contenido principal
Sony CPF-IP001 Buttons on Main Speaker Replacement
Qué necesitas
  1. Sony CPF-IP001 Buttons on Main Speaker Replacement, Main Speaker Housing Disassembly: paso 1, imagen 1 de 1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 2, imagen 1 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 2, imagen 2 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 2, imagen 3 de 3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 3, imagen 1 de 2 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 4, imagen 1 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 4, imagen 2 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 5, imagen 1 de 1
    • Remove two 5 mm Phillips #0 screws.
  6. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 6, imagen 1 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 6, imagen 2 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 6, imagen 3 de 3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
  7. Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: paso 7, imagen 1 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: paso 7, imagen 2 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement, Buttons on Main Speaker: paso 7, imagen 3 de 3
    • Remove two 6 mm Phillips #0 screws.
    • Gently lift the silver buttons up to remove.
  8. Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 8, imagen 1 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 8, imagen 2 de 3 Sony CPF-IP001 Buttons on Main Speaker Replacement: paso 8, imagen 3 de 3
    • Using the plastic opening tool, disconnect the white connector from the circuit board.
    • Replace the broken circuit board with a new one.
Conclusión
3 personas más completaron esta guía.
Cole Stanley
Miembro Desde 04/14/15
290 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-14, Maness Spring 2015 Miembro de Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 293
