Saltar al contenido principal
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
Qué necesitas
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: paso 1, imagen 1 de 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: paso 2, imagen 1 de 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: paso 2, imagen 2 de 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: paso 2, imagen 3 de 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 1,858
