Saltar al contenido principal
Sony CFD-8 Battery Replacement
  1. Sony CFD-8 Battery Replacement, Battery: paso 1, imagen 1 de 3 Sony CFD-8 Battery Replacement, Battery: paso 1, imagen 2 de 3 Sony CFD-8 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 Battery Replacement: paso 2, imagen 1 de 2 Sony CFD-8 Battery Replacement: paso 2, imagen 2 de 2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
Conclusión
Tess
Miembro Desde 10/14/14
439 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-38, Amido Fall 2014 Miembro de Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,270
