Saltar al contenido principal
Sony CDX-GT540UI Motherboard Replacement
Qué necesitas
  1. Sony CDX-GT540UI Motherboard Replacement, Front Panel: paso 1, imagen 1 de 1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI Motherboard Replacement: paso 2, imagen 1 de 2 Sony CDX-GT540UI Motherboard Replacement: paso 2, imagen 2 de 2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI Motherboard Replacement: paso 3, imagen 1 de 3 Sony CDX-GT540UI Motherboard Replacement: paso 3, imagen 2 de 3 Sony CDX-GT540UI Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI Motherboard Replacement: paso 4, imagen 1 de 2 Sony CDX-GT540UI Motherboard Replacement: paso 4, imagen 2 de 2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove front panel.
  6. Sony CDX-GT540UI Motherboard Replacement, Wiring Harness: paso 6, imagen 1 de 1
    • Locate the clip on the wiring harness.
  7. Sony CDX-GT540UI Motherboard Replacement: paso 7, imagen 1 de 2 Sony CDX-GT540UI Motherboard Replacement: paso 7, imagen 2 de 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  8. Sony CDX-GT540UI Motherboard Replacement, Back Panel: paso 8, imagen 1 de 1
    • Locate back panel.
  9. Sony CDX-GT540UI Motherboard Replacement: paso 9, imagen 1 de 3 Sony CDX-GT540UI Motherboard Replacement: paso 9, imagen 2 de 3 Sony CDX-GT540UI Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  10. Sony CDX-GT540UI Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  11. Sony CDX-GT540UI Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  12. Sony CDX-GT540UI Motherboard Replacement, CD Drive: paso 12, imagen 1 de 1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  13. Sony CDX-GT540UI Motherboard Replacement: paso 13, imagen 1 de 2 Sony CDX-GT540UI Motherboard Replacement: paso 13, imagen 2 de 2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  14. Sony CDX-GT540UI Motherboard Replacement: paso 14, imagen 1 de 2 Sony CDX-GT540UI Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove top panel.
  15. Sony CDX-GT540UI Motherboard Replacement: paso 15, imagen 1 de 1
    • Pull up CD drive slightly.
  16. Sony CDX-GT540UI Motherboard Replacement: paso 16, imagen 1 de 1
    • Disconnect motherboard connection.
  17. Sony CDX-GT540UI Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove CD drive.
  18. Sony CDX-GT540UI Motherboard Replacement, Motherboard: paso 18, imagen 1 de 1
    • Remove three 6.7mm Phillips 300 screws.
  19. Sony CDX-GT540UI Motherboard Replacement: paso 19, imagen 1 de 1
    • Pull motherboard up.
Conclusión
4 personas más completaron esta guía.
Odelkys Marquez
Miembro Desde 09/22/14
1,115 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 10-2, Brown Fall 2014 Miembro de USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
Miembros de 3
7 Guías creadas
1Guía Comentario
Card reader light bling but not on my car audio
Deepak Kumar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 2,307
