Saltar al contenido principal
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: paso 1, imagen 1 de 1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: paso 2, imagen 1 de 2 Sony CDX-GT540UI Fuse Replacement: paso 2, imagen 2 de 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: paso 3, imagen 1 de 1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: paso 4, imagen 1 de 1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: paso 5, imagen 1 de 1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
Conclusión
Una persona más ha completado esta guía.
Odelkys Marquez
Miembro Desde 09/22/14
1,115 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 10-2, Brown Fall 2014 Miembro de USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
Miembros de 3
7 Guías creadas
1 Guide Comment
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 9,799
