Saltar al contenido principal
Sony CCD-TR81 Outer Case Replacement
Qué necesitas
  1. Sony CCD-TR81 Outer Case Replacement, Disassembling Sony CCD-TR81 Battery: paso 1, imagen 1 de 1
    • Lift viewfinder to access battery pack.
  2. Sony CCD-TR81 Outer Case Replacement: paso 2, imagen 1 de 2 Sony CCD-TR81 Outer Case Replacement: paso 2, imagen 2 de 2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. Sony CCD-TR81 Outer Case Replacement: paso 3, imagen 1 de 1
    • Pull the battery pack out of the video camera.
  4. Sony CCD-TR81 Outer Case Replacement, Outer Case: paso 4, imagen 1 de 3 Sony CCD-TR81 Outer Case Replacement, Outer Case: paso 4, imagen 2 de 3 Sony CCD-TR81 Outer Case Replacement, Outer Case: paso 4, imagen 3 de 3
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
  5. Sony CCD-TR81 Outer Case Replacement: paso 5, imagen 1 de 2 Sony CCD-TR81 Outer Case Replacement: paso 5, imagen 2 de 2
    • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
    • Remove the single 4.5 mm screw from the backside.
  6. Sony CCD-TR81 Outer Case Replacement: paso 6, imagen 1 de 1
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
  7. Sony CCD-TR81 Outer Case Replacement: paso 7, imagen 1 de 1
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
  8. Sony CCD-TR81 Outer Case Replacement: paso 8, imagen 1 de 1
    • Pull the bottom part of the case away from the camera.
  9. Sony CCD-TR81 Outer Case Replacement: paso 9, imagen 1 de 1
    • Remove the three 4.5 mm screws from the right face of the video camera.
  10. Sony CCD-TR81 Outer Case Replacement: paso 10, imagen 1 de 1
    • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
  11. Sony CCD-TR81 Outer Case Replacement: paso 11, imagen 1 de 1
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
  12. Sony CCD-TR81 Outer Case Replacement: paso 12, imagen 1 de 1
    • Remove two remaining 3.6 mm case screws from the front of the camera.
  13. Sony CCD-TR81 Outer Case Replacement: paso 13, imagen 1 de 2 Sony CCD-TR81 Outer Case Replacement: paso 13, imagen 2 de 2
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
Conclusión
Una persona más ha completado esta guía.
Kevin
Miembro Desde 01/24/11
232 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-25, Maness Winter 2011 Miembro de Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 3,371
