Saltar al contenido principal
Sony Bloggie 3D Player Main Button's Circuit Board Replacement
Qué necesitas
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: paso 1, imagen 1 de 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: paso 2, imagen 1 de 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: paso 3, imagen 1 de 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: paso 3, imagen 2 de 2
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Conclusión
Robert Tam
Miembro Desde 01/30/13
6 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-12, Maness Winter 2013 Miembro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 365
