Introducción
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Agregar Comentario
Use a plastic opening tool to pry the cover open.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Agregar Comentario
  • Detach the board from the ZIF connector using pair of tweezers or by hand.
  • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Agregar Comentario
Conclusión
Robert Tam
Miembro Desde 30/01/13
6 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-12, Maness Winter 2013 Miembro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 272
