Saltar al contenido principal
Sony Bloggie 3D Player Back Cover Replacement
Qué necesitas
  1. Sony Bloggie 3D Player Back Cover Replacement, Front Cover: paso 1, imagen 1 de 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Back Cover Replacement: paso 2, imagen 1 de 2 Sony Bloggie 3D Player Back Cover Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Back Cover Replacement, Back Cover: paso 3, imagen 1 de 2 Sony Bloggie 3D Player Back Cover Replacement, Back Cover: paso 3, imagen 2 de 2
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Back Cover Replacement: paso 4, imagen 1 de 2 Sony Bloggie 3D Player Back Cover Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
Conclusión
Timothy Tran
Miembro Desde 01/30/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-12, Maness Winter 2013 Miembro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 388
