Saltar al contenido principal
Sony Betamovie BMC-220 Cassette Compartment Replacement
Qué necesitas
  1. Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: paso 1, imagen 1 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: paso 1, imagen 2 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Battery: paso 1, imagen 3 de 3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 2, imagen 1 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 2, imagen 2 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 2, imagen 3 de 3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: paso 4, imagen 1 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: paso 4, imagen 2 de 3 Sony Betamovie BMC-220 Cassette Compartment Replacement, Cassette Compartment: paso 4, imagen 3 de 3
    • Remove the two screws (2mm x 6mm) at the base of the Cassette compartment using the Phillips #1 screwdriver.
    • Remove the two screws (2mm x 6mm) at the back of the Betamovie using the Phillips #2 screwdriver.
    • Once all of the screws are removed, pop the cassette cover off of the camera.
  5. Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 5, imagen 1 de 2 Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 5, imagen 2 de 2
    • Remove the silver piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 6, imagen 1 de 2 Sony Betamovie BMC-220 Cassette Compartment Replacement: paso 6, imagen 2 de 2
    • Remove the two screws (2mm x 6mm) underneath the cassette compartment on the bottom of the Betamovie with the Phillips #1 screwdriver.
    • Remove the bottom piece of the cassette compartment.
Conclusión
Un comentario
Do you know how to take out the Trinicon tube in this camera?
Kyle Gilchrist - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 663
