Saltar al contenido principal
Sony BDP-S3700 Motherboard Replacement
Qué necesitas
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: paso 1, imagen 1 de 2 Sony BDP-S3700 Motherboard Replacement, Front Panel: paso 1, imagen 2 de 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: paso 2, imagen 1 de 2 Sony BDP-S3700 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: paso 3, imagen 1 de 2 Sony BDP-S3700 Motherboard Replacement: paso 3, imagen 2 de 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: paso 4, imagen 1 de 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: paso 5, imagen 1 de 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: paso 5, imagen 2 de 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: paso 5, imagen 3 de 3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: paso 6, imagen 1 de 2 Sony BDP-S3700 Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: paso 7, imagen 1 de 1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 2 Sony BDP-S3700 Motherboard Replacement, Motherboard: paso 8, imagen 2 de 2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: paso 9, imagen 1 de 3 Sony BDP-S3700 Motherboard Replacement: paso 9, imagen 2 de 3 Sony BDP-S3700 Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: paso 10, imagen 1 de 3 Sony BDP-S3700 Motherboard Replacement: paso 10, imagen 2 de 3 Sony BDP-S3700 Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: paso 11, imagen 1 de 1
    • Carefully lift and pull the motherboard forward to remove.
Conclusión
2 personas más completaron esta guía.
Luiz Barreto
Miembro Desde 02/15/17
627 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 12-1, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Miembros
5 Guías creadas
2 comentarios
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - Contestar
Same problem here.
Julian Robbins -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,572
