Saltar al contenido principal
Sony BDP-S3200 Motherboard Replacement
Qué necesitas
  1. Sony BDP-S3200 Motherboard Replacement, Sony BDP-S3200 Disassembly: paso 1, imagen 1 de 1
    • Remove all cables from the device.
  2. Sony BDP-S3200 Motherboard Replacement: paso 2, imagen 1 de 2 Sony BDP-S3200 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200 Motherboard Replacement: paso 3, imagen 1 de 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Sony BDP-S3200 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Carefully detach the white strips from the motherboard.
    • Be sure to lift the black latch for the largest strip next to the disc drive before removing it.
  5. Sony BDP-S3200 Motherboard Replacement: paso 5, imagen 1 de 3 Sony BDP-S3200 Motherboard Replacement: paso 5, imagen 2 de 3 Sony BDP-S3200 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove screw above HDMI OUT port.
    • Remove screw above DIGITAL OUT port.
    • Remove the three screws on the motherboard.
    • Use a #1 Phillips screwdriver to remove all screws.
  6. Sony BDP-S3200 Motherboard Replacement: paso 6, imagen 1 de 2 Sony BDP-S3200 Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove motherboard from the device.
    • Be careful not to damage any components of the motherboard when removing it from the device.
Conclusión
3 personas más completaron esta guía.
Brandon Correa
Miembro Desde 10/03/17
158 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G2, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 396
