Saltar al contenido principal
Sony BDP-S3200 Disk Drive Replacement
Qué necesitas
  1. Sony BDP-S3200 Disk Drive Replacement, Sony BDP-S3200 Disassembly: paso 1, imagen 1 de 1
    • Remove all cables from the device.
  2. Sony BDP-S3200 Disk Drive Replacement: paso 2, imagen 1 de 2 Sony BDP-S3200 Disk Drive Replacement: paso 2, imagen 2 de 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200 Disk Drive Replacement: paso 3, imagen 1 de 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200 Disk Drive Replacement, Disk Drive Replacement: paso 4, imagen 1 de 1
    • Locate the disk drive
  5. Sony BDP-S3200 Disk Drive Replacement: paso 5, imagen 1 de 3 Sony BDP-S3200 Disk Drive Replacement: paso 5, imagen 2 de 3 Sony BDP-S3200 Disk Drive Replacement: paso 5, imagen 3 de 3
    • Lightly lift off the hook on both front rear side and the bottom of the device to remove the front panel
  6. Sony BDP-S3200 Disk Drive Replacement: paso 6, imagen 1 de 2 Sony BDP-S3200 Disk Drive Replacement: paso 6, imagen 2 de 2
    • Remove the two screws that attach the disk drive to the frame using a #1 Phillips screwdriver.
  7. Sony BDP-S3200 Disk Drive Replacement: paso 7, imagen 1 de 3 Sony BDP-S3200 Disk Drive Replacement: paso 7, imagen 2 de 3 Sony BDP-S3200 Disk Drive Replacement: paso 7, imagen 3 de 3
    • Carefully pull the (3) three bands off vertically.
    • NOTE: There is a latch that needs to be lifted off before pulling the band out for the middle band.
  8. Sony BDP-S3200 Disk Drive Replacement: paso 8, imagen 1 de 2 Sony BDP-S3200 Disk Drive Replacement: paso 8, imagen 2 de 2
    • Lift the disk drive off of the device
Conclusión
2 personas más completaron esta guía.
Tan Nguyen
Miembro Desde 10/03/17
132 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G2, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 Miembros
3 Guías creadas
Un comentario
Where can I buy a Sony BDP-S3200 Disc Drive Replacement?
Andrew Padilla - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 670
