Saltar al contenido principal
Sony BDP-BX620 Cover Removal
Qué necesitas
  1. Sony BDP-BX620 Cover Removal, Outer Cover: paso 1, imagen 1 de 2 Sony BDP-BX620 Cover Removal, Outer Cover: paso 1, imagen 2 de 2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Cover Removal: paso 2, imagen 1 de 2 Sony BDP-BX620 Cover Removal: paso 2, imagen 2 de 2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Cover Removal: paso 3, imagen 1 de 3 Sony BDP-BX620 Cover Removal: paso 3, imagen 2 de 3 Sony BDP-BX620 Cover Removal: paso 3, imagen 3 de 3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
Conclusión
Equipo
USF Tampa, Team 1-6, Lacy Fall 2016 Miembro de USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 220
