Saltar al contenido principal
Sony BDP-BX520 Disc Tray Replacement
Qué necesitas
  1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray Cover: paso 1, imagen 1 de 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Disc Tray Replacement: paso 2, imagen 1 de 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Disc Tray Replacement: paso 3, imagen 1 de 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Disc Tray Replacement, Top Case: paso 4, imagen 1 de 1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Disc Tray Replacement: paso 5, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement: paso 5, imagen 2 de 2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Disc Tray Replacement, Front Panel: paso 6, imagen 1 de 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Disc Tray Replacement: paso 7, imagen 1 de 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Disc Tray Replacement: paso 8, imagen 1 de 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Disc Tray Replacement: paso 9, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement: paso 9, imagen 2 de 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Disc Tray Replacement, Disc Tray: paso 10, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement, Disc Tray: paso 10, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
  11. Sony BDP-BX520 Disc Tray Replacement: paso 11, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement: paso 11, imagen 2 de 2
    • Pull the medium-sized 9 pin ribbon cable out of its connector on the motherboard.
  12. Sony BDP-BX520 Disc Tray Replacement: paso 12, imagen 1 de 3 Sony BDP-BX520 Disc Tray Replacement: paso 12, imagen 2 de 3 Sony BDP-BX520 Disc Tray Replacement: paso 12, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, lift up the tab of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of its connector.
  13. Sony BDP-BX520 Disc Tray Replacement: paso 13, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement: paso 13, imagen 2 de 2
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
  14. Sony BDP-BX520 Disc Tray Replacement: paso 14, imagen 1 de 2 Sony BDP-BX520 Disc Tray Replacement: paso 14, imagen 2 de 2
    • Slide the disk tray out from under the tabs on the case holding it down while lifting it out of the case.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 8-41, Amido Winter 2015 Miembro de Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Miembros
8 Guías creadas
2 comentarios
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
tomcerecedes - Contestar
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
Susan Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 7,416
