Saltar al contenido principal
Sony BDP-BX520 Bluetooth Module Replacement
Qué necesitas
  1. Sony BDP-BX520 Bluetooth Module Replacement, Disc Tray Cover: paso 1, imagen 1 de 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Bluetooth Module Replacement: paso 2, imagen 1 de 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Bluetooth Module Replacement: paso 3, imagen 1 de 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Bluetooth Module Replacement, Top Case: paso 4, imagen 1 de 1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Bluetooth Module Replacement: paso 5, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement: paso 5, imagen 2 de 2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Bluetooth Module Replacement, Front Panel: paso 6, imagen 1 de 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Bluetooth Module Replacement: paso 7, imagen 1 de 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Bluetooth Module Replacement: paso 8, imagen 1 de 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Bluetooth Module Replacement: paso 9, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement: paso 9, imagen 2 de 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Bluetooth Module Replacement, Port Board: paso 10, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement, Port Board: paso 10, imagen 2 de 2
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  11. Sony BDP-BX520 Bluetooth Module Replacement: paso 11, imagen 1 de 1
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  12. Sony BDP-BX520 Bluetooth Module Replacement: paso 12, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement: paso 12, imagen 2 de 2
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  13. Sony BDP-BX520 Bluetooth Module Replacement: paso 13, imagen 1 de 1
    • Carefully pull the port board free from the Blu-Ray player.
  14. Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: paso 14, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: paso 14, imagen 2 de 2
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
  15. Sony BDP-BX520 Bluetooth Module Replacement: paso 15, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the silver 8 mm screw attaching the Bluetooth module to the front of the case.
  16. Sony BDP-BX520 Bluetooth Module Replacement: paso 16, imagen 1 de 2 Sony BDP-BX520 Bluetooth Module Replacement: paso 16, imagen 2 de 2
    • Remove the Bluetooth module from the case.
    • Make sure to only touch the sides of the Bluetooth module when removing it from the case.
Conclusión
Equipo
Cal Poly, Team 8-41, Amido Winter 2015 Miembro de Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 424
