Introducción
In the situation that your Sony BDP-BX510 motherboard is not working, you may need to replace it. This guide will provide you with the steps required to safely remove your motherboard for replacement. The tools that are needed include a Phillips #2 screwdriver, Phillips #1 screwdriver, tweezers, and metal spudger.
Qué necesitas
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
Casi Terminas!
Conclusión
