Saltar al contenido principal
Sony BDP-6500 Disk Assembly Replacement
Qué necesitas
  1. Sony BDP-6500 Disk Assembly Replacement, Disk Assembly: paso 1, imagen 1 de 2 Sony BDP-6500 Disk Assembly Replacement, Disk Assembly: paso 1, imagen 2 de 2
    • Turn the player around so that the back is facing you.
  2. Sony BDP-6500 Disk Assembly Replacement: paso 2, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 2, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 2, imagen 3 de 3
    • Remove the three Phillips #1 screws.
  3. Sony BDP-6500 Disk Assembly Replacement: paso 3, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 3, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 3, imagen 3 de 3
    • Remove the top cover by sliding it off.
  4. Sony BDP-6500 Disk Assembly Replacement: paso 4, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 4, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 4, imagen 3 de 3
    • Turn the player around so that it appears as shown.
  5. Sony BDP-6500 Disk Assembly Replacement: paso 5, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 5, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Pull up the two tabs with a pair of plastic tweezers.
    • You can use any tool that will give you leverage to pull up the tabs. Alternatively, you can use your fingers, but it may be more difficult.
  6. Sony BDP-6500 Disk Assembly Replacement: paso 6, imagen 1 de 1
    • Slightly pull off the front cover.
    • You will only be able to partially remove the front cover at this point. Keep pulling off until you feel resistance from the other side.
  7. Sony BDP-6500 Disk Assembly Replacement: paso 7, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 7, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 7, imagen 3 de 3
    • Pull up the two tabs on the other side using a pair of tweezers.
    • Pull the front cover off.
  8. Sony BDP-6500 Disk Assembly Replacement: paso 8, imagen 1 de 1
    • Orient the player as shown.
  9. Sony BDP-6500 Disk Assembly Replacement: paso 9, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 9, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 9, imagen 3 de 3
    • Remove the two Phillips #1 screws using a screwdriver.
  10. Sony BDP-6500 Disk Assembly Replacement: paso 10, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 10, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 10, imagen 3 de 3
    • Pull the first of three ribbon wires out of its socket using your fingers.
    • You may experience significant resistance when pulling out each of the wires.
  11. Sony BDP-6500 Disk Assembly Replacement: paso 11, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 11, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 11, imagen 3 de 3
    • Pull the other two ribbon wires out of their sockets.
  12. Sony BDP-6500 Disk Assembly Replacement: paso 12, imagen 1 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 12, imagen 2 de 3 Sony BDP-6500 Disk Assembly Replacement: paso 12, imagen 3 de 3
    • Lift up the right side of the disk assembly.
    • Slide the disk assembly to the right.
    • Lift up the disk assembly to remove it.
    • Do not open up the disk assembly once you remove it from the player. If opened, your eyes may be harmed by the laser radiation from the disk lens within.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 519
