Saltar al contenido principal
Sony BDP BX350 Wifi Card Replacement
Qué necesitas
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: paso 1, imagen 1 de 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: paso 2, imagen 1 de 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: paso 3, imagen 1 de 1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: paso 4, imagen 1 de 1
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: paso 5, imagen 1 de 2 Sony BDP BX350 Wifi Card Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: paso 6, imagen 1 de 1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: paso 7, imagen 1 de 2 Sony BDP BX350 Wifi Card Replacement: paso 7, imagen 2 de 2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: paso 8, imagen 1 de 2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: paso 8, imagen 2 de 2
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: paso 9, imagen 1 de 1
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: paso 10, imagen 1 de 3 Sony BDP BX350 Wifi Card Replacement: paso 10, imagen 2 de 3 Sony BDP BX350 Wifi Card Replacement: paso 10, imagen 3 de 3
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
Conclusión
Kristen Vezina
Miembro Desde 03/06/17
413 Reputación
4 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 307
