Saltar al contenido principal
Sony BDP BX350 Disc Tray Replacement
Qué necesitas
  1. Sony BDP BX350 Disc Tray Replacement, Disc Assembly: paso 1, imagen 1 de 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Disc Tray Replacement: paso 2, imagen 1 de 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Disc Tray Replacement: paso 3, imagen 1 de 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Disc Tray Replacement: paso 4, imagen 1 de 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Disc Tray Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Disc Tray Replacement: paso 6, imagen 1 de 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Disc Tray Replacement: paso 7, imagen 1 de 1
    • Remove disc assembly.
  8. Sony BDP BX350 Disc Tray Replacement, Disc Tray: paso 8, imagen 1 de 1
    • Take caution to not break plastic tabs.
    • Undo the four tabs on the disc tray assembly.
  9. Sony BDP BX350 Disc Tray Replacement: paso 9, imagen 1 de 2 Sony BDP BX350 Disc Tray Replacement: paso 9, imagen 2 de 2
    • Lift front until back separates.
  10. Sony BDP BX350 Disc Tray Replacement: paso 10, imagen 1 de 1
    • Remove disc from disc tray.
Conclusión
To reassemble your device, follow these instructions in reverse order however do not put the disc back in.
Kristen Vezina
Miembro Desde 03/06/17
413 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 447
