Saltar al contenido principal
Sony BDP BX350 Disc Assembly Replacement
Qué necesitas
  1. Sony BDP BX350 Disc Assembly Replacement, Disc Assembly: paso 1, imagen 1 de 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Disc Assembly Replacement: paso 2, imagen 1 de 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Disc Assembly Replacement: paso 3, imagen 1 de 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Disc Assembly Replacement: paso 4, imagen 1 de 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Disc Assembly Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Disc Assembly Replacement: paso 6, imagen 1 de 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Disc Assembly Replacement: paso 7, imagen 1 de 1
    • Remove disc assembly.
Conclusión
Kristen Vezina
Miembro Desde 03/06/17
413 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 389
