Saltar al contenido principal
Sony BDP BX350 Device Control Board Replacement
Qué necesitas
  1. Sony BDP BX350  Device Control Board Replacement, Control Board: paso 1, imagen 1 de 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350  Device Control Board Replacement: paso 2, imagen 1 de 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350  Device Control Board Replacement: paso 3, imagen 1 de 1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350  Device Control Board Replacement: paso 4, imagen 1 de 1
    • Remove both covers.
  5. Sony BDP BX350  Device Control Board Replacement: paso 5, imagen 1 de 2 Sony BDP BX350  Device Control Board Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350  Device Control Board Replacement: paso 6, imagen 1 de 1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350  Device Control Board Replacement: paso 7, imagen 1 de 2 Sony BDP BX350  Device Control Board Replacement: paso 7, imagen 2 de 2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 513
