Saltar al contenido principal
Sony Alpha a7s II LCD Replacement
Qué necesitas
  1. Sony Alpha a7s II LCD Replacement, LCD: paso 1, imagen 1 de 1
    • Orient the camera so that the LCD screen is facing you.
  2. Sony Alpha a7s II LCD Replacement: paso 2, imagen 1 de 1
    • Lift the LCD screen to unscrew the 2 screws on its underside.
  3. Sony Alpha a7s II LCD Replacement: paso 3, imagen 1 de 1
    • Unscrew the 2 screws on the bottom of the LCD screen.
  4. Sony Alpha a7s II LCD Replacement: paso 4, imagen 1 de 1
    • Carefully remove the back of the LCD cover.
  5. Sony Alpha a7s II LCD Replacement: paso 5, imagen 1 de 1
    • Carefully pull up the LCD front cover from the metal internal frame.
    • Be careful of the wire ribbon as it is fragile.
Conclusión
7 personas más completaron esta guía.
4 comentarios
And the how do you change the LCD screen please ? How to remove it ?
timothee.ferreol - Contestar
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Viro Films - Contestar
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
Jean-Philippe Archibald - Contestar
What size screws!?
Alain Bucio - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 31
Ultimos 30 días: 95
Todo El Tiempo: 10,550
