Introducción
This replacement guide will address how to remove a faulty motherboard from a Sony Alpha a7s II camera. The motherboard acts as the brain of the camera. It serves as the centralized hub to connecting all other processes inside the camera together.
The LCD screen and memory card are examples of other parts that rely on the motherboard. Provided in this replacement guide are the steps needed to properly remove the motherboard.
Qué necesitas
Remove the six 4mm screws located at the bottom of the camera using Philips #000 (Circled in red).
Remove the two 3mm screws remaining on the base plate using Philips #000 (Circled in orange).
Remove the base plate.
2 comentarios
Where can I order the motherboard for this camera?
You can find replacement parts on Aliexpress.
