Saltar al contenido principal
Sony Alpha SLT-A55V Battery Replacement
Qué necesitas
  1. Sony Alpha SLT-A55V Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment on the bottom of the unit. Then, slide the latch down to open the cover.
  2. Sony Alpha SLT-A55V Battery Replacement: paso 2, imagen 1 de 1
    • Insert the new battery and close the compartment.
    • Most new lithium batteries are partially charged to improve shelf life. It is recommended to charge the battery after installation even if the indicator shows a full charge. Unlike nickel cadmium batteries, lithium batteries will provide better performance when charged to full capacity from a partial charge of 60%.
Conclusión
There you go, now you have a fully functional camera again. Do not forget to recharge the other battery to be prepared to repeat this guide.
Sultan Almunif
Miembro Desde 09/26/15
357 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-1, Wilson Fall 2015 Miembro de IUPUI, Team 1-1, Wilson Fall 2015
IUPUI-WILSON-F15S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,487
