Saltar al contenido principal
Sony Alpha NEX-C3 LCD Screen Replacement
Qué necesitas
  1. Sony Alpha NEX-C3 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Turn off the camera by sliding the power switch.
  2. Sony Alpha NEX-C3 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Tilt up the LCD screen.
  3. Sony Alpha NEX-C3 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Use a Phillips head 000 screwdriver to remove the two 2.0mm screws on the bottom of the LCD screen.
  4. Sony Alpha NEX-C3 LCD Screen Replacement: paso 4, imagen 1 de 3 Sony Alpha NEX-C3 LCD Screen Replacement: paso 4, imagen 2 de 3 Sony Alpha NEX-C3 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the smaller backplate of the LCD screen that covers the ribbon cable.
    • The smaller backplate should easily come off. Put it to the side.
  5. Sony Alpha NEX-C3 LCD Screen Replacement: paso 5, imagen 1 de 2 Sony Alpha NEX-C3 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the bigger backplate of the LCD.
  6. Sony Alpha NEX-C3 LCD Screen Replacement: paso 6, imagen 1 de 2 Sony Alpha NEX-C3 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, remove the larger backplate from the LCD screen.
  7. Sony Alpha NEX-C3 LCD Screen Replacement: paso 7, imagen 1 de 1
    • With your hands, gently remove the black plastic piece on the backside of the LCD screen.
  8. Sony Alpha NEX-C3 LCD Screen Replacement: paso 8, imagen 1 de 2 Sony Alpha NEX-C3 LCD Screen Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, gently pull up and away on the ribbon cable connected to the motherboard, after which, the LCD screen should come off.
    • The motherboard ribbon cable has a specific connector.
Conclusión
To reassemble your device, follow these instructions in reverse order. However, when installing the ribbon cable, the connector has a specific step. The connector has a tiny flap that clamps down onto the ribbon cable in order to make it secure.
Una persona más ha completado esta guía.
Jonathan Chen
Miembro Desde 10/17/17
690 Reputación
6 Guías creadas
Equipo
Un comentario
Sir, my unit has many lines that appear on the screen. However, the lcd glass is pristine & has no cracks. Which part is defective? Is the lcd mother board the culprit? Thank you.
Stevie B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 30
Todo El Tiempo: 2,520
