Saltar al contenido principal
Sony Alpha NEX-C3 Control Wheel Replacement
Qué necesitas
  1. Sony Alpha NEX-C3 Control Wheel Replacement, Top Panel: paso 1, imagen 1 de 1
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Control Wheel Replacement: paso 2, imagen 1 de 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Control Wheel Replacement: paso 3, imagen 1 de 1
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Control Wheel Replacement: paso 4, imagen 1 de 2 Sony Alpha NEX-C3 Control Wheel Replacement: paso 4, imagen 2 de 2
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Control Wheel Replacement: paso 5, imagen 1 de 1
    • Gently lift off the top panel with your hands.
  6. Sony Alpha NEX-C3 Control Wheel Replacement, Back Panel: paso 6, imagen 1 de 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
  7. Sony Alpha NEX-C3 Control Wheel Replacement: paso 7, imagen 1 de 2 Sony Alpha NEX-C3 Control Wheel Replacement: paso 7, imagen 2 de 2
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
  8. Sony Alpha NEX-C3 Control Wheel Replacement: paso 8, imagen 1 de 1
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
  9. Sony Alpha NEX-C3 Control Wheel Replacement: paso 9, imagen 1 de 1
    • Gently pry off the back panel, by wiggling it around the LCD screen.
  10. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: paso 10, imagen 1 de 2 Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: paso 10, imagen 2 de 2
    • Grab the silver plate, and gently pry it up.
  11. Sony Alpha NEX-C3 Control Wheel Replacement: paso 11, imagen 1 de 2 Sony Alpha NEX-C3 Control Wheel Replacement: paso 11, imagen 2 de 2
    • Gently pinch blue ribbon cable, and pull it out of the port.
Conclusión
3 personas más completaron esta guía.
Jonathan Chen
Miembro Desde 10/17/17
690 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 3,126
