Saltar al contenido principal
Sony Alpha NEX-6 Lens Replacement
  1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: paso 1, imagen 1 de 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: paso 2, imagen 1 de 2 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: paso 2, imagen 2 de 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
Conclusión
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
2 personas más completaron esta guía.
Clayton Dale
Miembro Desde 01/20/15
1,067 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 2,541
