Saltar al contenido principal
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: paso 2, imagen 1 de 2 Sony Alpha NEX-5N Battery Replacement: paso 2, imagen 2 de 2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: paso 3, imagen 1 de 2 Sony Alpha NEX-5N Battery Replacement: paso 3, imagen 2 de 2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
Conclusión
Demi Deletang
Miembro Desde 09/28/15
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 39
Todo El Tiempo: 2,436
