Saltar al contenido principal
Sony Alpha ILCE-6000 Lens Replacement
Qué necesitas
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: paso 1, imagen 1 de 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: paso 2, imagen 1 de 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: paso 3, imagen 1 de 2 Sony Alpha ILCE-6000 Lens Replacement: paso 3, imagen 2 de 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
Conclusión
Vuong Nguyen
Miembro Desde 02/02/17
122 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-4, Rose Winter 2017 Miembro de UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Miembros
10 Guías creadas
Un comentario
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 2,022
