Saltar al contenido principal
Sony Alpha ILCE-6000 E-mount Replacement
Qué necesitas
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: paso 1, imagen 1 de 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: paso 2, imagen 1 de 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: paso 3, imagen 1 de 2 Sony Alpha ILCE-6000 E-mount Replacement: paso 3, imagen 2 de 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: paso 4, imagen 1 de 2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: paso 4, imagen 2 de 2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: paso 5, imagen 1 de 3 Sony Alpha ILCE-6000 E-mount Replacement: paso 5, imagen 2 de 3 Sony Alpha ILCE-6000 E-mount Replacement: paso 5, imagen 3 de 3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: paso 6, imagen 1 de 3 Sony Alpha ILCE-6000 E-mount Replacement: paso 6, imagen 2 de 3 Sony Alpha ILCE-6000 E-mount Replacement: paso 6, imagen 3 de 3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: paso 7, imagen 1 de 1
    • Replace the plastic E-mount ring with a new one.
Conclusión
Yirga Yilma
Miembro Desde 02/02/17
221 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team 1-4, Rose Winter 2017 Miembro de UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Miembros
10 Guías creadas
2 comentarios
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Contestar
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 50
Todo El Tiempo: 3,742
