Saltar al contenido principal
Sony Alpha DSLR- A850 Viewfinder Window Replacement
Qué necesitas
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: paso 1, imagen 1 de 1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: paso 2, imagen 1 de 1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: paso 3, imagen 1 de 1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: paso 4, imagen 1 de 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: paso 4, imagen 2 de 2
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: paso 5, imagen 1 de 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement: paso 5, imagen 2 de 2
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: paso 6, imagen 1 de 1
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 391
