Saltar al contenido principal
Sony Alpha DSLR- A850 Viewfinder Cover Replacement
Qué necesitas
  1. Sony Alpha DSLR- A850 Viewfinder Cover Replacement, Viewfinder Cover: paso 1, imagen 1 de 1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: paso 2, imagen 1 de 1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: paso 3, imagen 1 de 1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 427
