Saltar al contenido principal
Sony Alpha A350 Front Case Replacement
Qué necesitas
  1. Sony Alpha A350 Front Case Replacement, Front Case: paso 1, imagen 1 de 2 Sony Alpha A350 Front Case Replacement, Front Case: paso 1, imagen 2 de 2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: paso 2, imagen 1 de 2 Sony Alpha A350 Front Case Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: paso 3, imagen 1 de 2 Sony Alpha A350 Front Case Replacement: paso 3, imagen 2 de 2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: paso 4, imagen 1 de 2 Sony Alpha A350 Front Case Replacement: paso 4, imagen 2 de 2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: paso 5, imagen 1 de 2 Sony Alpha A350 Front Case Replacement: paso 5, imagen 2 de 2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Conclusión
Equipo
IUPUI, Team S1-G6, Henning Fall 2019 Miembro de IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 749
