Saltar al contenido principal
Sony Alpha A3000 Motherboard Replacement
Qué necesitas
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: paso 1, imagen 1 de 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: paso 1, imagen 2 de 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: paso 1, imagen 3 de 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: paso 2, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: paso 3, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement: paso 3, imagen 2 de 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: paso 5, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: paso 6, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: paso 9, imagen 1 de 2 Sony Alpha A3000 Motherboard Replacement: paso 9, imagen 2 de 2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: paso 10, imagen 1 de 1
    • Finally remove the motherboard from the casing.
Conclusión
6 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-4, Meier Fall 2015 Miembro de USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Miembros
10 Guías creadas
Un comentario
Then loose the plug all the motherboard?
kongre172 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 2,422
