Saltar al contenido principal
Sony Alpha A3000 Battery Replacement
  1. Sony Alpha A3000 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • The battery compartment is located on the bottom of the camera as shown. To access the battery slide the compartment switch from LOCK to OPEN.
    • Before operating on device, ensure that the camera is powered off and the surface of operation is clean and free of dirt or other obstructions.
  2. Sony Alpha A3000 Battery Replacement: paso 2, imagen 1 de 1
    • Push back the blue tab releasing the battery which should spring forth on its own.
  3. Sony Alpha A3000 Battery Replacement: paso 3, imagen 1 de 1
    • To insert replacement, depress the blue tab again inserting the battery as shown until the blue tab springs back into place. Ensure battery is secure, close the battery compartment and return the latch to the LOCK position.
    • The replacement battery must meet specifications declared by Sony.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 4-4, Meier Fall 2015 Miembro de USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 2,183
