Introducción
If there are problems with the camera recognizing the press of the shutter button, this guide will show you step-by-step instructions on how to remove the button in order to replace it.
Qué necesitas
Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
Once the back cover is off, locate the flash of the camera and push it forward to open it
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
6 personas más completaron esta guía.
4 comentarios
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Where can i buy a replacement button?
You can find the flexible cable with the shutter button on aliexpress:
Thank you!
