Saltar al contenido principal
Sony Alpha 5100 Lens Replacement
  1. Sony Alpha 5100 Lens Replacement, Lens: paso 1, imagen 1 de 1
    • Place the camera in front so the lens is facing you. There should be a small button on the bottom left side of the lens.
  2. Sony Alpha 5100 Lens Replacement: paso 2, imagen 1 de 1
    • While holding down the button with your left thumb, use your right hand to twist the lens counterclockwise.
    • Make sure that you are twisting the bottom end of the lens.
  3. Sony Alpha 5100 Lens Replacement: paso 3, imagen 1 de 1
    • To insert a new lens, align the marking on the lens to the marking on the mount on the camera body.
    • Once insert correctly, you can twist the lens in clockwise direction easily until it clicks.
Conclusión
Quang Phan
Miembro Desde 10/30/19
97 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 914
