Saltar al contenido principal
Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: paso 1, imagen 1 de 2 Sony Alpha 5100 Front Plate Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: paso 2, imagen 1 de 1
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: paso 3, imagen 1 de 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: paso 3, imagen 2 de 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: paso 3, imagen 3 de 3
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: paso 4, imagen 1 de 2 Sony Alpha 5100 Front Plate Replacement: paso 4, imagen 2 de 2
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: paso 5, imagen 1 de 2 Sony Alpha 5100 Front Plate Replacement: paso 5, imagen 2 de 2
    • Use the opening tool to gently pop the front plate apart from the body.
Conclusión
Kevin Raggiani
Miembro Desde 10/30/19
444 Reputación
3 Guías creadas
Equipo
Un comentario
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 34
Todo El Tiempo: 1,246
